sell/transfer wireless Joey? | SatelliteGuys.US
zim2dive
669
21
Cary, NC
Paid $50 for a wireless Joey a few years ago which I don't need now.. can I resell it? (ie. can someone else use it and avoid the $50 charge? or would it somehow be locked to my acct or not able to be used for a new customer?)
thanks
Mike
thanks
Mike
DO YOU OWN IT? MOST ARE LEASED FROM DISH.
No need to YELL at the guy. :D
To the OP, whom did you purchase it from? If you paid the $50 to Dish, then you probably are leasing it. You could PM a DIRT member on the board to clarify if you own or lease the Joey, per their records. If you own it outright , you should be able to sell it.
AFAIK the $50 is for the Wireless Access Point (WAP) and not for the wireless Joey itself.
U344 - can't record /set up timers
Hopper 3 Timer issues
