Series Recording issues... | SatelliteGuys.US
tward392
38
Maryland
Noticed a few Series Recordings I had setup on my Genie did not or were not set up to record:
1. Killjoys on SyFy - it recorded last weeks fine, but I noticed it didn't record this weeks.
2. Humans on AMC - wasn't going to record the first episode at all.
Not sure what was going on with them.
Luckily they repeat a few times so I was able to record a later showing.
Removed the Series Recordings and set them back up and I believe now they are fine.
Also noticed that Rectify is returning soon and mine seemed to still be set up to record on the SD channel instead of the new HD channel...
Ever since the last software update My Genie 44-500 is broken. It seems to have trouble with "First Run" timers. I think it might be Guide issues.
You should call it in, the more people to call it in, the more likely they are to fix it.
DIRECTV's "NFL Sunday Ticket" Is Subject of Antitrust Lawsuit
Does DirecTV ever do free previews of their higher end packages?
