SES-11 ? | SatelliteGuys.US
SES-11 ?
James KD8FHC
16
4
Kaleva , Michigan
Hi guys I am a little confused on one satellite? My list shows SES-11 at 105w, but my receiver shows up as AMC-18? , Are they one of the same? Or do I have something set wrong? Looks like SES-11 was launched in 2017 and AMC-18 in 2006, any help would be appreciated thank you Jim Gauthier
SES-11 replaced AMC-18 at 105 °W and AMC-18 has since moved to 139 °W. The Ku part of SES-11 is known as EchoStar 105, but SES-11 and EchoStar 105 are the same satellite. All you need to do is manually update the names in your receiver if you want them to be accurate.
Thank you, a lot to learn for sure, but a lot of fun, all I have to do now is figure out how to put it in my linkbox 9000i
Reactions: kofi123
Does Echostar lease the space on 105 Ku?
Yes, since 2006.
Reactions: comfortably_numb
The satellite names change over time so best to use the orbital location (97W, 105W, 111W, etc) in your receiver and when posting as that usually does not change. :)
SES1
Just received a Channel Master 84E with dual LNB holder.
