Setting the receiver to channel 4 | SatelliteGuys.US
sbsi
451
Currently the receiver is set to channel 3. But, I see a lot of fuzzy picture when it is set on channel 3.
Can someone tell me how to set the receiver to tv channel 4?
It would sure help if you gave a model# of the receiver, since there's only been DOZEN's of D* models made over the years... :confused:
But, if it's NOT a switch on the back, then it should be in the setup menu of your receiver.
Actually, I don't remember EVER seeing that option on any of the newer rec's.
SBSI,
Do you not have any other connections on your TV, Component or Composite would be a better way to go.
IF you only have the RF input available, run down to BB or Radio Shack and get a converter.
While I know all the new H/HD & R22 boxes don't, actually the standard (D12) SD receivers STILL do:
DIRECTV: Standard Receiver
But again, if the OP would give a model# - a little common sense here, you know... :rolleyes:
SBSI,
The OP already said it ALREADY puts out on ch 3; he just wants to change it to 4... ;) ;)
SBSI,
Yes, a VCD/DVD recorder combo.
do you have your directv receiver ran through the VCR/DVD using coax, then to the TV using coax? if so, make sure you turn off the power to the VCR/DVD when watching directv, though ideally you should use composite/s-video/component if available
2.4 METER DISH - DIRECT TV
Any upcoming HD DVR models?
