Setting up 3 tv2 remotes to work simultaneously | SatelliteGuys.US
Sponge14
SatelliteGuys Guru
122
So I have 3 tv 2 remotes. The one I had, which is labeled as a model number 6.3, and 2 new ones from Ebay, model 6.0
I have a 722 receiver and I want to know how to get all 3 to work. I followed Dish's instructions and tried to make all 3 of them to the same address by going into system info and pressing the record button 3 times. It says that 2 remotes can't have the same address, so how do I get all 3 remotes to work tv2?
set up the remote like you would normally do but dont press record
press and hold "sat" button till it blinks
press the remote address (1,2,3,etc)
press #
thats it
should work
kewl
I knew it worked that way with the older UHF remotes for my 811...figured it still worked the same with the newer receivers :)
Looking at going HD
What HD channels do you want added next?
