Hello everyone,I'm a new member and I'm trying to use a 1000.2 dish and a dish pro lnb
to hook up a Wally.Do I need any kind of switch between lnb and Wally? Thanks in advance.
If you check the satellite status in diagnostics, which slot has 129? The correct order is 119/110/129, so if you are seeing Conn/Conn/129 you are on the right track. But if you see something like 129/Conn/Conn or Conn/129/Conn then you are receiving 129 on the wrong LNB, which means your elevation and/or skew is set incorrectly.
