Setting up new tailgate system | SatelliteGuys.US
mcr0320
3
atlanta
Hello all,
New to this site and needed some advise . Can I use one of my current DTV boxes (non-HD) from my home with a Dual LNB portable sat to get a tailgate system up and going?
Assuming you're talking about a single-LNB with 2 outputs, aka a DirecTV "basic" dish pointed at the 101 sat, then, yes, absolutely. Folks do it all the time.
i tried it out this afternoon with no luck I couldnt get any feedback from the transponder signal pointing sat s at about 46 dgree angle... any feedback i'm new at this so bear with me ..
You need the alignment parameters for where the tailgate will be. :)
With the 101 sat only dish, make sure you change the sat setup in the receiver to that dish.
Is the SL3 lnb toast?
DirectTV setup - no odd transponders
