Setting up TV2 on a 722 | SatelliteGuys.US
Hikerdave
23
Hi,
Are there instructions on how to setup TV2 to another TV for my 722? What I am looking for is what kind of connections I need and if I can do it myself or do I need Dish to come out to do it?
I did a Google search, but did not find anything (my search terms maybe bad) I also poked around the Dish web site with no luck.
Did you read the 722's manual?
Blasphemy!!!
Page 107.
Actually, the manual doesn't really detail the cabling very well. If you don't have the wherewithal to build your own cables, I suggest contracting it done.
On the other hand, if you can read the legends on the jacks on the back of the DVR (or page 21), you can easily figure out the wiring part. The key phrase is "home distribution".
Hurry up February 2nd.. So we can get past all this crap!!
Can someone with Center Ice check channel 628HD plz?
