setting which tuner use to record a show? Consecutive shows on same channel using different timers | SatelliteGuys.US
jpw711
66
Springfield MO Area
Anybody know how to make the hopper use the "green" (or blue) tuner each time the hopper records a show on the same channel?
Here's the deal, my wife sets the hopper up to record 8 top chefs in a row on the same channel, hitting the record button for each show individually. Looking at the timer, at 4PM, it's going to use the green timer, at 5PM, it's going to use the blue timer, at 6PM, back to the green. So every hour, hopper comes up and wants to change the channel that is currently being watched to record top chef, deleting any time I've got saved up on the show I'm watching. I've gone in and manually changed the start early/end late times to zero, this doesn't help. Short of going in and making one timer to record "all", is there another way?
This was an "improvement", which allows recording the entrance and exit extensions of the show. Before you would be hard cut from one show to the next and thus miss the vital leading or trailing words on each recording.
It would seem they could still record those but from the same tuner and get both the overlap not cut and use only one tuner, but one improvement at a time, I guess.
The manual timer would be a hard cut from one recording to the next. I'm not sure which it uses if all tuners are in use.
-Ken
You're doing the same thing my Aunt was doing for her Love it or List it Habit. I got her to change to setting timers differently, and she likes it better: Always et SERIES timers (New or New and Repeats) NOT one-time timers:
1. Hopper will automatically handle conflicts such as when a show airs more than once on the same day or more than one in the same week. For example, if there is a conflict and no tuners available for the first airing of that episode, the DVR will automatically record the very NEXT showing of the same episode, often just 3 hours later. This also applies if the episode won't be repeated until a few day. It will NOT record any recordings you already have (sometimes I think it does) and does all this automatically. Setting ONE-TIME timers will make a mess of trying to record what everyone wants. If your wife doesn't want to wait until the next showing 3 hours later, than she can place her Series timer at the higher priority. In that case she get her show recorded first, and the other shows get recorded later.
2. Often people who set one-time timers like you wife, often record what they already have recorded on the DVR or record an episode they have already seen. On a SERIES Timer, there will be an red X on the guide for that show meaning that she already has recorded on the DVR for New and Rerun timer or it is not NEW for the Only New timer. No sucking up timers just because she THINKS she hasn't seen it just want to go hog wild. The DVR is doing all that work for you. Otherwise, she is gonna suck up tuners unnecessarily. The hopper can manage that far better automatically. If she is afraid of having not seen a show, then she can set her SERIES timer for New and Reruns, then she won't miss any old ones she has not see.
Believe me. Simplify your life. One-time timers, unless set to the wee hours, is just an unnecessary frustration like you are experiencing. By the way, it makes no difference which timers does the recording. They are colored for us just to know at a glance that we have ONE or TWO or THREE things recording at that time. It is all automated and trying to always have a particular timer you prefer to record is just not how it is designed or necessary. Good luck.
If only the Hopper was handling timers like DishSubLA says... It USED to... All the screwy timer issues since 2 updates ago have really fouled things up. I have lots of series timers NOT picking up the next airing when there are conflicts or better yet, saying it is picking them up only to inexplicably not record them, along with all the other wacky issues with timers and tuners.
Thanks for the post, I'll tell her to start doing it the series way. That would make it easier for her anyway.
Don't tell her how to do it, just change it yourself ! :D Otherwise, you're likely to get a "I like doing it my way" or similar argument !
Hopper/Super joey setup?
Advice on changing packages
