Setup Help Needed | SatelliteGuys.US
Setup Help Needed
thecultfan
3
MA
Can someone tell me how to setup the following correctly:
Boxen: 811, 510 and 301
Dish: 500
Switches: DP34 and SW21
I have 3 rooms 1 box in each, any help is appreciated! Let me know if you need more info.
Well........................
Depending on what is on the Dish500 for the LNB, that makes the difference...but for sake of argument...lets say its a "DishPro Twin" (it has the big "DishPro" logo on the front)
-You would run 2 wires from the LNB (Dish500) down to the DP34 switch (the SW21 wont be used in this)
-run the 3 lines from the DP34 out to the receivers.
