SF250A Android Smart Phone Satellite Finder Meter | SatelliteGuys.US
wallyhts
Staff member
HERE TO HELP YOU!
3,219
448
DMSI has started selling this meter. Any One tried it?
This unique meter works with your Android smart phone, tablet or other Android devices. Just put the SF250A in your LNBF to Receiver line and you will be able to read signal strength and more on your Android device.
Currently available for Android devices only.
Not for use on DSS satellites.
Huge list of satellites and channels. Easily to edit channels or add new channels.
FEATURES
  • Low noise figure
  • Signal Strength and Signal Level LED Indicator
  • Signal lock LED indicator
  • Built-in Bluetooth BLE for connecting to Android devices
  • 13V/18V LED indicator
  • Beeper for remind signal lock function support
  • 1 satellite / 4TP and one LNB type parameters preset
Where's the magic words DVBS2 ? ;) First impression is that it's just a little too much gimmick and not enough meter for the job. The idea of a two piece meter is not appealing to me.
Don't have time to post much right now but did a quick search on eBay and found a link to the user manual at http://giftsconsidered.com/documents/SF250A-User Manual.pdf - haven't read it yet though.
The listing on eBay says:
Symbol rate 45 Msps for QPSK, 8PSK, 16APSK; 37Msps for 32APSK
So it would have to do DVB-S2 to deal with 8PSK, 16APSK, 32APSK, at least I would assume that.
SF250A Android Smart Phone Satellite Finder MeterNEW!!! Just released!!!
FEATURES
Low noise figureSignal Strength and Signal Level LED IndicatorSignal lock LED indicatorBuilt-in Bluetooth BLE for connecting to Android devices13V/18V LED indicatorBeeper for remind signal lock function support1 satellite / 4TP and one LNB type parameters preset
SF250A User Manual
Tuner DVB-S2Demodulator ModeQPSK, 8PSK, 16APSK, 32APSKInput Frequency950~2150MHzInput Impedance75?, Input Level -65dBm ~ 0dBmSymbol rate45 Msps for QPSK, 8PSK, 16APSK; 37Msps for 32APSKCode rate1/2, 2/3, 3/4, 3/5, 5/6, 7/8, 8/9, 9/10PowerDC Input RangeDC 13V/18VPhysical FeaturesTemperature range0 °c - 60 °cMax.relative humidity45%-75% RHSize(WxDxH) in mm140 * 89* 27.4MM
Sent from my SM-G860P using Tapatalk
DirecTV slimine dish re-purposed as 2m ham antenna
Sky Speaker Satellite Meter - Hamfest Find
