Noticed that there was about a 3% reduction in Signal Quality with the motor inline.
Cut the foil coil at the LNBF connector and inserted a 1 Uh choke @ .65 Amps.
Signal Quality increased by 3%.
[FONT=Fixedsys]..
. +------------ LNB
.rcvr --------+
. +---@@@@@---- motor
. (choke)
.[/FONT]
Smith, P how did you bypass the motor? Did you make an internal modification or an external one?
I choose to use a 2x1, 2GHz, 2port power passing splitter. The loss of the splitter is much less than the DiSEqC motors. Most HH motors introduce at least a 7 - 10dB degradation.
Had a discussion last week with a customer who experienced a 48% Signal Quality for GMTN on AMC4 through a motor and 72% SQ with direct connection. He used a 2x1 splitter, 2Ghz, 2PPP and was happy with a 67% SQ.
Motors are good for moving, but not kind to signals!
Brent,
While your waiting for your order, setup your dish on a weak but vieable signal, goto the dishmotor and disconnect the cables and insert a F series female coupler. Now read your signal quality.
Tom
Interesting, Do you work in Schaumburg ? I've been there for several 800mhz trunking classes.At Motorola we use a loss figure of .25 db for every N type connector inline at 450 Mhz. So at 1.5Ghz and F connectors it's probably a lot more. 1 db being about 20%
Limited time offer
