Shaw 75 CM dish on SuperDISH mount? | SatelliteGuys.US
Skylooker
60
Northeast Indiana
I have a SuperDISH 85 cm dish and the mount to attach the antenna to the roof. What I'm wondering is of the Shaw 75 cm dish will fit on that mount. I don't have the Shaw dish or any specs on the mount diameter. I'd like to put the mount on the roof in advance of the weather turning cold. I should have the Shaw dish in a few weeks and could then just put it on the old SuperDISH mount, if it will fit.
I haven't measured the mount post on the SuperDISH mount yet, but I can if someone has the measurement for the clamp mount assembly on the Shaw 75 cm dish.
Thanks!
Thanks mellaby. The mount is up. Looks good. ImageUploadedBySatelliteGuys1382311974.995981.jpg Wish I could say the same for the roof of my garage.
Posted Via The SatelliteGuys Reader App!
