Shaw Direct set up | SatelliteGuys.US
Shaw Direct set up
Also please confirm:
Shaw is currently broadcasting on two satellites: Anik F1/F1R (107W) and Anik F2 (111W).
Is it correct that sat G1 (107W) will be added ?
Is it correct that G1 will be out of range in the Southern US states?
Thanks !
p.s. what model of LNB and switch will I be needing ?
I am way South in Belize and need to use my own 6 foot offset dish.
I do not understand what type of LNB ? Ku yes ? linear, circular ?
would a regular Dish Legacy Lnb or a Directv lnb work ?
Why a quad switch if I just combine 2 satellites ?
I see you are in Belize farther south (and east) than I am, I read in another post you require a 1.8 meter dish to get a signal.
In my location I use 2 dishes, a 1.8 meter pointed at Anik F2 @ 111w and a 1.2 meter at Anik F1 @ 107w.
Even though I know (and I´ve done it) it´s possible to get both sats with just the 1.8 meter dish, adjusting both LNBs in a multi lnb bracket.
Shaw is scheduled to launch a G1 and the souther US will be out of footprint (actually most of the US).
This G1 I understand was scheduled to be launched by the end of this year or beginning of next one.
Linear LNBs are required, I have Standard Ku LNBs for each dish, connected with an Ecoda 0/22 khz switch (950-2150 Mhz)
so a standard linear lnb ?. . . like any old Directv or Dish Legacy ? not FSS ?
A standard lnb like those used for FTA, I use DMS International JSC321S, Directv and Dish used circular LNB´s, but most of the FTA satelites and Shaw Direct are linear.
ok, now I understand, thank you.
R/L means circular and V/H is linear
That brings me to another problem: I do have a punch of Lnbs around but non says R/L or H/V just the frequency is printed.
I know the Fortec Universal FSKU V2 I used to use for FTA and it should be linear.
Exactly, but the lnb´s don´t show H/V or such, most (if not practically all) of the LNB´s used for FTA are linear.
ok, now I completely understand.
Are there any real good linear LNBs on the market or should I just go with another Fortec ? I will need to purchase a second linear lnb anyhow.
thanks.
Ok, my questions are:
* Can I search for Shaw Direct signals with an offset dish, the Fortec lnb and a Lexium DBS7000 box ? (meaning not using a Shaw receiver)
* Any specific transponder I should use ?
thanks.
You may want to check AV Satellites and sadoun, they carry some good LNB´s
I also have an Invacom QPH-031 linear and circular. I guess that would work for Shaw as well.
Now a stupid question:
* for Shaw, would both work: offset and prime focus (same size = 6 foot, I am in Belize) using a the QPH-031 in linear ?
* * Can I search for Shaw Direct signals with the Invacom lnb and a Lexium DBS7000 box ? (meaning not using a Shaw receiver --just for searching (not viewing) to see signal strength)
* Any specific transponder I should use for the search ?
Thanks.
Thanks.
Both offset and prime focus should work with Invacom. They do make ku lnb's designed for a prime focus dish. This should give you higher signal. I think SatAv sells them.
You can search for shaw signals using Fta box. For 111 west, use 11720V, 3269 freq, 5/6 FEC. Check the top of page for link to the"List" for other transponders.
If you are going for both satellites, not sure about your Fortec universal. Shaw uses 22 khz for switching satellites. The universal Lnb uses 22khz for high band, so this may interfere with sat switching. You would definitely have to use it for the 22khz sat. It seems to me I tried this once and had difficulty. Too long ago to remember exactly
Catamount
I will start searching for signal with an off-set dish, my Lexium DBS7000 and the QHP-031.
Any specific TP I should be using ?
Any other advise I might not know ?
I guess Anik F1R would be the satellite as it has some free channels (until I get a sub receiver)
Thanks, Wolfgang
Additional Hockey on SD
Anik G1 went up today!
