shaw direct | SatelliteGuys.US
shaw direct
mjlafleur
25
alberta
what channel should I be on with shaw direct 505 receiver and 60 dish in mesa .AZ to set it up
Is the LNB down here the same as Canada? If it is just tune to 299. I assume you had the 505 running in Canada. You can PM me if you like I'm not that far from you.
Yes it is the same LNB and was activated in AB I have in az already but we are moving and had forgot what channel to put it on. If I have problem I will PM you Mellby TY very much
