Hey everyone. I'm looking to find a sat finder for Shaw. Sat is in Caribbean area. And any direction is helpful too. Any help would be greatly appreciated. Thanks in advance.
Sorry, that was not very helpful!
I'm looking to buy a satellite locator for Shaw Direct. I'm helping someone setup a dish and we are trying to find the signal. Have not had any luck yet. Thank you for your help.
Shaw satellites use the same intermediate frequency as everyone else so pretty much any of the satellite finders you see will work for signal levels.Hey everyone. I'm looking to find a sat finder for Shaw. Sat is in Caribbean area. And any direction is helpful too. Any help would be greatly appreciated. Thanks in advance.
Is your dish stationary or do you move around a lot?
I was referring to any of the inexpensive squawk meters (typically less than 20% of the cost of a replacement battery for a Birddog). They aren't confounded by modulation or encryption schemes as they're looking only for a carrier.@ Harshness, that is not completely correct. Since Shaw uses digicypher and now Turbo 8psk transponders, only the newest Birddog and expensive Applied Instruments meters will get a signal. I checked about this a few months back. There was an inexpensive "sqauker meter" that Shaw used to recommend on their website.
No personal experience, but the coverage maps at satbeams.com for 107W and 111W are somewhat grim (Anik G1 doesn't go beyond the mid US).Does anybody have experience with Shaw in the Caribbean area?
Thanks for the replies everyone. Does anybody have experience with Shaw in the Caribbean area?
A 75E is the only model you should consider using. 60E models are useless on weaker HD signals, which may be an issue on a few channels found on F2. Before you waste too much time looking for an unknown signal, connect your receiver to someone's working system and make sure that you have some authorized channels actually working on your receiver. Then connect to a new dish, first confirming that you have the same type of LNBF as on their system, so there is a match.So with that said, does anybody have any tips to get a dish aligned? Last time we were there we could not get a signal at all with a 60E dish and a new xKu lnb. Next try will be with a 75E and xKu lnb.
Latitude 17.7429
Longitude -88.0243
Settings tried already:
Elevation 65.4
Azimuth 234.5
Skew 140.8
Nothing of the sort! Someone is telling you a big Fib. Satellites don't move for one and until F1 & F2 need to be replaced it will never be a Canada only thing. (If then even) Especially When the Shaw boys own a house in Phoneix. If that was the case my phone would be ringing off the hook and every single customer would need their dish re aimed.
Satellites can't change their coverage patterns by moving to a different location. Satellites can't move north or south in any case.We learned that Shaw was focusing on the oil fields up north and moved the satellite.
Some satellites may be able to change their coverage area either by tilting the satellite or redirecting their horns so it is possible that Shaw is engaging in that activity.Someone is telling you a big Fib. Satellites don't move for one and until F1 & F2 need to be replaced it will never be a Canada only thing.
Limited time offer
