Shopping Cart confusion | SatelliteGuys.US
Magic Static
7,498
4,853
Montana
I ordered a couple of microHDs and applied the promocode "newmicro" . It didn't display the charges correctly. The conformation email showed the correct billing.
And the promo code didn't add the switches into the invoicing. I don't know that it is supposed to do that. But the important thing is the order is in and the price is right. :)
After some thought, I think it's just that you have to apply the promocode for each unit and I only did one. maybe?
The Ecoda 22KHz switches are added by our sales department when they review and approve your order. The switch will not appear on the initial order confirmation email, but the switch will appear on the invoice provided with the shipping alert email.
You should enter the promo code once and it is multiplied by the total quantity of receivers. I will look at your specific order if you could PM or call with the order number. Thank you for your assistance!
New microHD Firmware File Release and Notes 2012.06.15
microHD: Sharing DiSEqC 1.2 Motors and Controllers
