Should I Self-Install a Bigger Dish? | SatelliteGuys.US
Lars
93
Living in the Deep South, I have T-storm issues like everyone else. Even with a 96 signal strength, I lose the signal sometimes for up to an hour, depending on the movement of the storm. I have an unused D* three LNB oval dish in my basement. Should I hook it up and use it for Voom until they supply their own larger dish in Oct? Will the D* oval dish help at all with signal strength over the Voom pizza pan?
[VOOM] Re: Should I Self-Install a Bigger Dish?
Yes a bigger dish will help. Dont know about the oval though.
else. Even
three
Voom
dish
> Lars
------------------------ Yahoo! Groups Sponsor --------------------~-->
Make a clean sweep of pop-up ads. Yahoo! Companion Toolbar.
Now with Pop-Up Blocker. Get it for free!
http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/EyMolB/TM
Yahoo! Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
<*> To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
I was thinking the same thing, im in the same situation.... be sure to post here if you see any improvements if you do the switch :)
I did purchase my own 30" dish and self installed it. The 18" dish
that Voom installed would fail (no Voom signal) if there was rain
clouds south-east from me.
I have not seen any rain fade since I installed the 30" dish.
The larger dish did not fix the micro-stutter and STB lock-ups.
Still waiting on a software upgrade to fix those issues.
Currently though, I only watch Voom about 2 minutes per day. Just
enough time to check to see if the new software is here....
to
> DRAKO
Yahoo! Groups Links
Ive contempated the same thing, throwing my D* dish back up and pointing it at rainbow1. Let us know how it works.
F
[VOOM] Blue tint around people on my screen?
[WILT] WM9/MPEG4 and upgrade idea...
