Should NASCAR go electric? | SatelliteGuys.US
Poke
13,886
238
OK
Hmm would be interesting for sure..
http://www.theverge.com/2016/2/4/10916924/nascar-electric-cars-bill-nye-formula-e
Last week, Bill Nye started a bit of a storm with this post on Aeon: "If NASCAR embraced electric cars it could change the world." In it, Nye expands on a chapter from his most recent book, where he calls for NASCAR to ditch its internal combustion engines and replace them with electric ones. "We could convert all of our racecars to electricity — right now — and show the public exactly what electrons can do," Nye says.
Many of the reactions have been predictably angry. People won't like the lack of engine noise! NASCAR already does a lot for environmental programs!
The tone sounds familiar to that of the reactions when all-electric racing series Formula E made its debut in 2014. And guess what? Those fears were unfounded. Formula E is already a plenty good racing series, and it's just as exciting up close, even without all the engine noise and methanol fumes.
But a full-on bait-and-switch will never work. NASCAR would crumble overnight if it went all-electric, and besides, he glosses over a few (big) technological barriers.
Nye starts by touching on the argument that, in some respects, electric cars can outperform cars that use internal combustion engines. He's right; the P85D and P90D versions of the Model S have beaten some of the best cars in the world in various drag races. And while he points out that the Tesla Model S weighs more and puts out less horsepower than a typical NASCAR car, Nye believes that giving a company like Tesla a few years might be enough to level the playing field a bit.
A poster on Jalopnik's community blog, Opposite Lock, went even deeper, factoring in how new rules in NASCAR will limit the horsepower while pointing out that Road and Track got a much higher horsepower reading when it tested the Model S. And, as the post shows, the 0-60 times between NASCAR and a Model S are basically the same.
But there are some big hangups. The Model S is speed limited to 155mph, and even if Tesla bumped up the Model S's top speed, the battery would likely get much worse mileage at sustained, high speeds.
And that brings us to the biggest barrier that no one has quite solved. With a few more years, Tesla might be able to eke enough performance out of the Model S to have it compete in a straight line with the likes of Kyle Busch. But the batteries that power electric cars are still nowhere near being able to last on the big oval tracks that NASCAR spends most of its season running on. These tracks offer little to no opportunity for regenerative braking, which adds energy back into the battery. Worse, too much heat will build up in the batteries if you push an electric motor that hard for that long.
Both of these issues play a big role in Formula E, which Nye either chose to ignore in his piece, or flat out doesn't know about yet. Those cars can only make it through about 25 to 30 minutes worth of racing before their batteries die, and that's with the ability to use regenerative braking in just about every corner. And during each race, the drivers have to worry about the heat in the battery almost as much as they have to monitor the remaining energy.
"The two most important factors that we look at during any race is thermal management and energy management," Dilbagh Gil, team principal for the Mahindra Formula E team, told me last month. "Last year, many times we finished the race with energy left over in the car which we couldn’t utilize because we had maxed out on temperature."
Formula E runs its races on tight street circuits, while NASCAR typically competes on oval tracks that are up to 2.5 miles long. And they run much longer races than Formula E, too, often eclipsing 400 or even 500 miles.
John Waters, who developed the battery packs that powered GM's ill-fated EV1, touched on this a few years ago. At the 246th National Meeting & Exposition of the American Chemical Society, he said that "racing in excess of 150 mph on high-speed ovals will take a significant breakthrough in battery technology for EV race cars, or racetracks, to be competitive in the Indianapolis 500 or NASCAR events."
NASCAR might be able to get away with electric stock cars on the series' smallest half-mile tracks like Martinsville or Bristol, where braking in the corners could help keep the battery alive a little longer. But it would take many more years before an electric car runs 500 miles at Daytona.
NASCAR SHOULD EXPERIMENT
I'm fine with Nye wanting NASCAR to head in this direction. In fact, I think any motorsports series — big or small — should be considering how they can incorporate electric vehicles into their products. I don't want to see every internal combustion racing series die off, but there should be room to test out EVs as a support series, similar to how Formula E will run a driverless series, Roborace, next season.
And Nye even sort of accidentally proposes this at one point. "There’s no reason why NASCAR couldn’t be like that: a race with rules designed to reward the coolest, most advanced vehicle technologies," he says. But instead of asking NASCAR to replace its entire racing product at once, we should be asking the series to start by adopting this kind of contest as a supplement to the main series.
Without easing fans into EV racing, racing culture will always fight it. Even then, it'll be an uphill battle — I've seen lifer race fans walk down grandstand steps backwards because they didn't want to watch the supporting class on the track.
Formula E may have already found fans who don't want to deal with loud engines or gas fumes, but it has the advantage of being a global series. NASCAR is as American as it gets, and we're a country that just bought more internal combustion cars than ever in 2015. Even as the series struggles, Nye's dream is still a long way from reality — but that doesn't mean NASCAR can't start down that road right now.
Something really wrong and inefficient with batteries overheating. That may be "the way it is" today, but that is wasted energy. Better batteries would not have this problem.
OK- we need TWO revolutions in battery technology.
In the TOP series, Hell No ...
Now, if they so desired, I could see them starting an Electric series a step or two below the Truck series.
I would like to see it start in a lower series to see how much the cost will be overall before they go to the main series.
Reactions: Jimbo and stardust3
THIS THREAD:
Lets hit the catch fence at Daytona and fling acid all over the crowd, NOT!
Answer: stay home.
There is nothing like the all powerful roar of a 700 + horsepower engine X 43.
The noise, the fumes and the layer of tire rubber on your beer is what makes it exciting.
Take that away... big snooze fest.
Reactions: SamCdbs
so run 50 miles, take a 4 hour pit stop to top off the batteries? ok thats exciting
but it would let the driver take a nap
Nascar has changed quite a lot over the years. And not for the better in some ways in my opinion. I dislike the concept of "restrictor plates". For me the technological contest between car manufacturers was on of the most intriguing aspects of the race. Of course things have to be made safer and that alone is a big factor in how things are done. But it's all about the drivers now and little is said about the cars other than references to sponsorship.
Taking ICE out of Nascar would be like the NFL switching to soccer. Not what people want done. But many folks enjoy both sports. I think Nascar should get into electric racing. It would be fun if they didn't over regulate it. If they let the technological competition back into the game.
If a Tesla slams the wall at over 150mph, you won't have an acid bath but you will likely incinerate the driver pretty quick.
Reactions: osu1991
Just put a 2000 watt audio system in those electric NASCARs and have a recorded engine noise blasting out... timed to the electric motor revs. :rolleyes: Should appeal to all the Millennials that have their heads buried in their cell phones. There's NO replacement for displacement. NASCAR died when they restricted engine size and added restrictor plates. They need to remove the big, tall fences in front of the lower stands while they are at it. Not worth going to a NASCAR race without at least some chance of having a car end up in your lap. :biggrin
Reactions: fred555
Electric cars (which run on coal) are a technological dead end.
Even if that scientific fact were not true, it has no application for racing.
BTW, the current (no pun intended) state of batteries is that a car could run at speed around Daytona for a lap and a half before going dead.
So you think ICEs are not nearing their end, for automobiles?
You think nuclear, solar, hydro and wind are going away?
I like the IROC idea, but NASCAR died for me when they stopped using "stock" cars. At least Formula 1 has pushed the technology in hybrid poweplants. Hopefully the innovations there make it into the cars we can afford to drive.
The Formula E series requires that the cars are exchanged halfway through the race since the current battery technology can handle the race distance. That may be necessary to avoid a 4 hour charge pitstop, but it resets any car damage the driver might have incurred during the first half of the race.
Lewis Hamilton was on James Cordon's Late Late Show and James asked Lewis if he would try Formula E. Lewis's answer was classic (in a nutshell: no interest).
If we look at this idea from a proper perspective we may find that in reality an electric vehicle, properly designed, will have very little in common with what is running in NASCAR now. Electric racing will be very different from what we are used to seeing. When I was in High school I raced model slot cars on a professionally built Gran Prix style track 200 ft long. In scale mph, I would run 900mph lap speeds. LOL I could imagine a full scale track with electric cars. No batteries needed ;)
