Should you be worried about the Prop 65 warnings on almost everything? | SatelliteGuys.US
OK, there comes a point where even a so-called “coastal elitist” says, enough.
The State of California mandates that a warning be placed on any device, any part, and in any location where any potentially cancer-causing material can exist. The warning was approved by voters in 1986 as Proposition 65, and that’s the name people generally use for these sorts of warnings. But has it gone too far? I mean, it seems like this warning is on everything, including walking into most stores.
What does Prop 65 actually save you from?​
There’s a ridiculously long list published by the California government here. It includes lead (used in solder on circuit boards), cadmium (used in some batteries) and lithium (used in the batteries that don’t contain cadmium.) Virtually any electronic device will have at least one of these materials. Period. There’s no getting around it.
Once you’re informed about these bad materials, you should know not to put them in your bodies or in the water. So, there you go.
What does it all mean?​
It means, don’t put your electronics in water. I think you knew that.
It means, don’t eat or even lick your electronics. Again, pretty sure you knew that.
It also means, unfortunately, that pretty much everything in our modern world has the potential to cause cancer and poison the environment. Of course that’s a very bad thing and no one wants to have cancer or poison anything. But it does sort of seem that the Prop 65 warning itself isn’t going to stop that. It’s so common that it’s lost its meaning.
Prop 65 has done good things, to be sure. Increasing awareness of these toxic chemicals has led to cleaner air and water. That’s definitely good. I simply wonder if labeling every single electronic bit of everything with a Prop 65 warning is going to really make a difference now. By labeling virtually everything the same way and not telling people what the real risk is from each thing, it just trains us to ignore that warning altogether. I mean, if I saw it on a candy bar I’d probably question that. But how many people actually read the full wrappers on candy bars before eating them?
What is there to do?​
Honestly, unless you’re planning on going Amish, there’s not a lot that you can to do avoid every single chemical on that list. You can try to be responsible, and you can try to support manufacturers that have responsible policies. When they break, you can recycle your used electronics instead of putting them in a landfill. You can decide not to put them in your mouth. But really, when it comes to trying to get away from a Proposition 65 warning, honestly you’re not going to get very far. You’ll find them all over everything you truly want to buy.
And, that does include the things we sell at Solid Signal. Because we do business in California, you’ll find the Prop 65 warning at the bottom of some of the things we sell. If you have any questions about that or anything you find at solidsignal.com, call us at 888-233-7563 or fill out the form below.
The post Should you be worried about the Prop 65 warnings on almost everything? appeared first on The Solid Signal Blog.
Continue reading...
Who Read This Thread (Total Members: 8)
