signal level 66% is that means lnb is not good enough? | SatelliteGuys.US
dzhan
41
I have picked some sats alway with signal level 66% or less no matter has I move the dish, angel etc. Is that means the lnb is not good enough? thanks.
66% signal or quality?
Some quality signals may be low due to the powert hey are putting out or dish size :)
66% signal is fine...it's QUALITY that matters
What receiver are you using?
Make sure you look for the Quality not only signal level.
Also, verify that you have your LNBF settings and Transponder parameters correct.
Twinhan 102g Help!!!
What Satellite is closest to my true South(Longitude)?
