signal loss | SatelliteGuys.US
signal loss
vmaxed
40
CT
How much signal loss is there when you use a F type barrel connector female to female in a RG-6 Coax Cable run. I need to use two in 40ft for OTA on a 622 ?
Thanks...Ed:hatsoff:
It will not hurt with the 40' run with two barrel connectors. Typically, it maybe 3 dB loss.
like anything else there are different grades of f-f barrel connectors . I use ones rated for 3 ghz.
approx. .2 db loss per supplier documentation.
Thanks for your replies. I see how it works out tomorrow with a DB2 UHF HDTV OTA Antenna :up
Ed..:wave
KEPR 19-1 Tri-Cities, WA
TVision
