I have a HR22-100 HD DVR, standard DVR-16-300, and Standard D-12 500 in my 3 rooms. I've had NO issues with the HR22 or D-12.
However, my DVR-16-300 has had satellite issues for 4 days straight. I just had the system installed 10 days ago. I have a slimline dish-5S with SWM. I have been unable to acquire a signal on this receiver, but then suddenly it returns and the TV works. At times the tv plays the wrong channel (plays an infomercial on a network channel, for instance).
I did a system check and everything says OK. I've done several resets, and sometimes it is simply not able to recognize a satellite signal and it stays stuck at 0%. The frustrating thing is that it works sometimes. Again, the other TVs are fine.
The tech installed this unit with the existing wiring in the house. Does that matter? Is it a SWM issue, or LNB issue?
Any ideas out there?
