Signal Strength- 103(b) | SatelliteGuys.US
gordoinaz
3
Does anyone know if I either have poor alignment or a bad b-band converter? I have no signal strengths for 103(b), should I?
Yes you should have signal.
It could be setup wrong (3lnb instead of 5 lnb) or bad converters, or bad receiver, or bad alignment.
I am getting between 90 and 96 on all transponders on 103b on both of my of my tuners. I would check the alignment first before calling to get a new converter.
I checked my signal strength on 103b without the converter and zero's all around. My receiver is set to 5lnb. Any thing else to check?
Dish alignment? Bad lnb?
What are the signal strengths on the other satellites?
Have you tried resetting the receiver? Do you have no signal on both tuners?
gord,
I'm experiancing the the same thing. I am missing 11 HD channels that were released today :( When I run the Sat Setup my Sat 103(b) Fails. I have no clue what this means yet. But I will find out.
Just got off the phone with Direct TV
Troubleshooting 103(b) Signal Issues
