signal strength help | SatelliteGuys.US
horizon
38
I'm looking at IA-13. I've got a 10' BUD with a fortec lifetime classic NA FTA receiver and C-band.
When I look at 4186-v-5185 I get a locked indicator and level of 80%, those channels are fine.
3940-v-29270 it is unlocked and levels bounce from 0-26%
3900-v-27684 is locked with a steady 66%
Is there an easy answer why 3940-v-29270 is off compared to the others on that satellite for my setup?
(My BUD came with the house and I've just started to crank it up) It's got a 40degree c-band LNB, which I gather a lower degree rating is better.
ia-13
Your fortec and many other fta receivers will identify digicipher 2 transponder data streams but it cannot play them, even if they are free to air. Although Motorola claims digicipher 2 is mpeg-2, it is not compatible with the rest of the world.
Digicipher 2 is more complex in the way that it maps and tables the virtual channels.
Look at WWW.LYNGSAT.com, go to "frequencies" and pick "echo9-IA13" look at tp's and what's on them. Look for the ones that say "F" free tv, and DVB.
Hope that helps-trucker:)
My Pansat and my Coolsat wouldn't register any signal quality on a DC transponder. It would see the DVB variants though (Nag / powervu, etc).
ASC421 Install getting UGLY
Tweeking the BUD
