Signal strength on 129 | SatelliteGuys.US
rockymtnhigh
Hardly Normal
30,520
1,161
Normal, IL
Anybody in the midwest (Illinois particularly), I am trying to get a sense of how strong my signal strength should be on 129. GoalieBob and I tried to peak the dish today (the installer had the elevation and skew off, both by 2), and I am getting about 45-50 for 129; much higher for 119.
I was finding I easily lose signal during pretty much any rain, and wanted to at least optimize the dish's settings.
That's what GoalieBob and I were guessing, the new meters.... :rolleyes:
But thanks for confirming that!
But in trying to peak the dish we also realized the installer did a crap job; we put a bubble level on it, and it is off; and the thing has too much give; its bracketed to the wall, but probably should be on a pole mount. I am guessing that is causing as much of the problem in rain storms.
Always something to work on :)
what signals are you getting on 119?
110 -- 66
119 -- 72
129 -- 53
The numbers are 13 higher on 129 then they were before we adjusted it.
I haven't had any problems the past week, but it hasn't rained either :)
I will play with different transponders to see how the numbers vary.
yeah you're on the new system of signal meter
I just checked mine on the 811. This has the old meter and I was using the 129 LNB I have next to my G10 LNB on a Primestar dish so we're working with just a little bigger dish (40x30)
most TP's that registered were at 75
TP13 seemed to be the highest at 94
a few were in the high 70's near 80
converselly 119 is 100+ on most TP's
Fading Drifting Audio - Help
DFW HD Dish
