Signal strength on Dish 1000? | SatelliteGuys.US
fish2222
74
Hey guys, I just recently got a 622 installed, along with a Dish 1000... Anyway, its pointed at the two main satellites and 129 of course. What are you guys getting for signal strength on the 129 sat? I can only get about 58-60 if I am lucky, and rain fade is very bad. The other two sats are 90-105 and don't seem to have that issue. Would I be better off getting a 500 and pointing it at the 129 sat? If I do that, can I use the built in switch in the 1000 and not have to get dp44 if I unhook the 129 LNB? Thanks!
If you're losing pic due to rain fade call dish and complain.
Ask for a dish 1000.2
In the meantime, use your cell phone out at your dish (if possible).
Then, fish2222 phone home.
Nudge the dish left and then right slightly and get a report from 'home'
If signal level increases on 129 tr31, slightly bend the dish/mount till sig stays where you want it. Only do this if the two post nuts are tightened down very good. (you don't want to swing it on the post!!)
fred
Improve TV2 Quality on 622
Why would you want an 811??
