signal strength | SatelliteGuys.US
signal strength
jhall2005
39
what is the average signal strength on satellites 119, 110, and 129 run? my 129 goes off a lot just even when a small cloud comes up.
Well, my old Dish 1000 looks just about average for this DMA, although a couple of my TPs on 129 are 4-5 points higher that the average TP19=56; TP29=57.
And this is in a room where the line runs all the way around the house (maybe 70 ft from the DP44).
Are there any trees or other obstructions in the line of sight (note that the line of sight is some 15-20 degrees higher than what it appears to be.)
Any return of the UFC 6-Pack?
Need help with Radio Shack 8-1 universal remote and dish dp311
