Signal Strength | SatelliteGuys.US
Signal Strength
jesserulz233
139
South Carolina
Can anybody tell me normal signal strengths for thr 99, 103, and 110. My 110's are all in the upper 90's but my 103's are in the 70's. My SWM reads in the the upper 90's as well. Reason being is I am having a lot of rain fade on my HD channels
The ss numbers on 99s and 103s are spot beams. They could be anywhere from 0 to 100. The other 99 and 103 sats should be at least in the mid 80s, more like low to mid 90s. It sounds like your dish needs an alignment. 110 is only being used for Puerto Rico I think.
Just look at 101, 99c, 103ca and 103cb, don't bother with the others.
Except for a few transponders that are spotbeams and might be low or even zero, 101 should all be in the 90s or even 100. 99c, 103ca and 103cb should all be in the high 80s to mid 90s
DirectTV remote
Directv iPad App Update 8/13
