Signal to TV2 | SatelliteGuys.US
Signal to TV2
satvad
38
I have dishnetwork with dual receiver 522. Initially it was setup for use with two TVs. However I was using it only on single TV in single mode. Now I got a Second TV, so I switched back to dual mode. But some how I could not able to get the signal to the second TV. I verified the channel, and it is showing as 60. I tried up to channel 69 but no signal is coming. I am at a loss to understand what the problem is. Any suggestions appreciated.
Make sure you are not set up for cable on your TV2. I believe it should be set to air. Your tv could show it in the 100s if you do a channel search. It is easier to switch to air and tune to 60
yes, it was using cable before. Changed to Antenna and did a channel search and working correctly now. Thx.
Dish being fought by EFF.
Dish dropping out every day
