Simple question, I think | SatelliteGuys.US
double play is a way to activate a double buffer. You can run the buffer on two different channels at the same time. That way you can switch back and forth and by rewinding or pausing; you can watch two shows at once.
Pretty cool indeed. I take it that you can still record while using double play?
there is two tuners so if you're recording a ball game and watching say "All Worked up" on Tru TV if you use the doubleplay you can flip between the two. (not that I would do that...hee hee) Since you're recording something that buffer is already being used
After almost 16 years I cancelled today.
Bye.
Calling dual buffers "Doubleplay" really irritated me (of course that is not the reason I cancelled).
No PIP for D*?
Got an HR22 and Two R22's....MRV?
