I'm looking for advice on my two options. I have a Dish1000 installed and a Dish500 sitting in the shed.
With the current setup, after peaking for hours, the best I can get is:
110 - 74pts (on trans 21)
119 - 82pts (on trans 21)
129 - 61pts (on trans 21)
Should I use my extra 500 for 110 & 119 and then the 1000 for 129 only? (LNB on center position)
Or should I peak the 1000 for the best 110-119 and use the 500 for 129? (using "I" adapter)
Anyone compared the two?
Pro's and Con's of each option?
