singnaloc pro | SatelliteGuys.US
singnaloc pro
jackal2403
27
does anyone have a link to where i could get directions for the signaloc pro directions in pdf format to i could print them out? thanxs
can you use the sathawk 3000 flashes on a signaloc-pro meter? does anybody know where to find directions for the signaloc meter?
The Signaloc-Pro and the SatHawk 3000 meter come from the same factory. The user instructions are pretty much the same: http://sathawk.tv/Instructions.htm
As far as the datafiles are concernered there are no guarantee the datafile flashes will work. The two meters may have different processor chip lots, making the satloader and sat files incompatible.
If you use the SatHawk 3000 data files, you are doing it at your own risk. :(
UonTV?
102g install
