SIR-MINI w/ Audiovox SIRCK2 / SIRPNP2 Help? | SatelliteGuys.US
Lou4Gehrig
15
I needed to replace the OEM antenna, so I bought an SIR-MINI. This has the green connector which I guess is called the FAKRA-type SMB. The back of my cradle has the one input for SAT (main) and one input for TER. I guess I might need the splitter, but the SIR-SP doesn't look right to me, since that has the same type of green connector. Is that what I need, or can I use something else to get by? Thanks.
Lou
Lou
This is beyond my level of help. Please post you question
HERE and I am sure you get a good answer. Provide all detailed information you can.
Good luck and let us know what happens. :)
Sirius or XM
