SiriusXM missing from Dishanywhere | SatelliteGuys.US
monymony
11
3
Hello All,
This is my first post after moving to Dish after 12+ years with Directv. So far Hopper3 is great!
Anyway, over the past few weeks I have been tuning to channel 99 to listen to some of the SiriusXM stations via my laptop. This has works well. This morning channel 99 is missing from the guide list on both my laptop and my mobile app. Is this something that was expected? I have searched and did not find anything about this so figured I would post and try to figure out what is up.
Thanks!
SiriusXm isn't supposed to be listed in the guide on DishAnywhere but you can still listen to it. All you need to do is once you have connected to live just type in the Sirius channel you want to listen to. Use all five digits, 099xx for the channel you want.
Worked like a charm! Thanks for the quick response.
I will say I was surprised when I first started using DishAnywhere that SiriusXM channels were in the guide.
How can I get Dish to fix this issue? Help
Hopper 3 composite output video letterbox, but guide is anamorphic
