Skew, Elevation, and Az for 129 on Standalone Dish | SatelliteGuys.US
Swoop
40
So after finding out that a Dish 1000.2 won't work in my neck of the woods I have ordered a second dish with a DP Dual LNB so that I can pick up 129. Could someone who's in the know possibly give me the Skew, Az and Elev for a single Dish pointed at 129 for Zipcode 32060. Also I assume I can just run a cable from the DP Dual LNB to the 3rd port on my DPP 44 Switch. Thanks
With 129 on it's on dish you won't need to set the skew. Put in right in the middle. Skew is only for multi-sat dish.
Are you sure that you can get 129 in Florida? If you look at this map, part of Florida is excluded from the footprint for 129:
http://ekb.dbstalk.com/pictures/Dish1000Exclusions.jpg
Why Hawaii and Alaska get HDNet/Discovery HD in mpeg4?
need help with 1000
