Skew for Primestar dish? | SatelliteGuys.US
sam mudface
20
what is the screw for primestar dish in oklahoma 73082 pansat 2700a for ia5 sat
Hi Sam
the skew for each satellite is slightly different , now the only time that is different is when its mounted on a motor. then usually set at zero and the motor handles it.
but if you post your zip here i'm sure Pete will print you up a sat list with the skew for each.
73082
Latitude 34° 46.248'N Longitude 97° 56.586'W
Sat Name Sat Lng Az(t) Az(m) El Skew
Telstar 5 97.0W 178.3 172.5 49.6 -1.4
Satellite Finder is (c) Copyright 2004, P. Lutus
Telstar 5 is IA5 very little skew
Will an SG2100 work with a 31" Alphastar Dish?
Upper, Lower Vertical and Horizontal
