Sky Angel and Windows Media Center Vista | SatelliteGuys.US
Qpupdish
9
Does anyone know how to set-up SkyAngel IPTV to work with Windows Media Center Vista Home Premium edition?
Thank you.
Thank you.
Yes. You need to connect the receiver to the SVideo input on your desktop. You will still need to use the Sky Angel Remote and the guide is not part of Windows Media Center. The quality is great and you can watch SA while you work.
You will also need to change the configuration on the SA box in setup to SVideo, or you will
get a black and white picture.
Question
Are you able to record shows using Windows Media Center? Can you set it up to record ahead of time or only real-time?
Thanks!
I would not purchase or lease a New Sky Angel Receiver!!!
Sky Angel and Snapstream BeyondTV
