Sky Angel / Antenna / TiVo? | SatelliteGuys.US
skip4hym
3
Tyler, Texas
I have a TiVo 2 Single Tuner DVR, recieving Sky Angel and Over the Air Antenna. I am only able to record One Channel at a time...and...I have to watch THAT Channel.
A Dual Tuner will not work with Sky Angel/Antenna.
IS there a way to record a Channel and watch another Channel at the same time?
You can reply to: skipym@yahoo.com
You would have to get a 2nd Sky Angel box and have enough download speed for two video streams. I think you have to call SA to get pricing for the 2nd box.
Not at Problem!
Antenna IN to the Converter Box, then to TiVo IN!
Sky Angel OUT to TiVo!
I have an IR on EACH Box for Remote Channel Changing!
Keep in Mind that I can ONLY use a Single Tuner TiVo for this type of Incoming Signals.
I'm considering going back to cable, and using my Dual Tuner TiVo!
NFL Red Zone
Sky Angel and TIVO
