SkyAngel IPTV and Media Center 2005 | SatelliteGuys.US
dlhusk
4
Can anyone please help me to figure out how to get SA and MCE2005 working together, in particular how I can use Media center to schedule and record shows?
Thanks In Advance,
Dan
You need an "IR blaster" type device. They not only receive IR (infrared) signals from a remote but they can also transmit IR signals to control a set-top box.
Here are some directions from Microsoft
Windows XP Media Center Edition 2005: Media Center and your set-top box
They talk about using a coax cable to the MCE tuner card but it may work with a video cable (composite, s-video or component) from the SA box to your MCE card. I don't use MCE so I don't know for sure. I know it would work with some of the other available media center software.
If your current remote receiver does not support transmitting IR, you could get one like this.
Pinnacle Systems - Product summary - Pinnacle Remote Kit for Windows Media Center
Says it will control any set-top box but I don't know for sure if it works with the SA box.
Automate, Thanks for the reply. Sorry I did not get back sooner but been busy. I will look over the info.
Dan
Using DVD/VCR Recorder w/SkyAngel
Sky Angel IPTV Programming II
