slack on SG2100 | SatelliteGuys.US
slack on SG2100
GreatFTA
1,389
15
Mississippi Delta
Hi guys!
The other day I replaced my 1 meter Primestar dish with a 1.2 meter Primestar and I noticed there is some side to side slack on my Moteck SG2100 arm. Not much but when I go from one satellite to another I have to toggle my dish a little to get the satellite in.
Is there anyway to tighten down the arm so it wouldn't rock anymore?
mrftaman did you remove the shaft and see if its the shaft or the motor itself
if its the shaft you might can shim it , if its the motor then its probably the gears, don't know a fix for that. are you using the 42mm shaft or the 50 mm shaft
i did notice the 50 mm shaft compensated for a little bit of movement on mine.
Strange problem on BEC 2000
pansat 6000
