slimeline 3 | SatelliteGuys.US
slimeline 3
trikydiky
14
hi all..Ihave a question...hope someone can help.... today I did a triple satellite instal....3 slimeline 3 dishes... I did 2 no problems..the third was a nightmare..did same set up as other2.. checked sats...only found 101. checked signal strength..95 on 101 0 on 99 and 86 on 103..recheked and rechecked...no difference..swaped lnbf with working dish..no difference..swaped receiver with working system ...no difference . Does anyone have any ideas?? . The only thing I did not do is change the dish. It has a clear line of site. when I do a check it does not even see 103, just 101 but the meter says 86 on 103... Could the dish be bent ! any help would be appreciated.
Thanks trikydiky
The dish could well be bent. It doesn't take much to muck up the signals.
remote won't work
Slimline 3 self install
