Slimline 3, Sat 99 Issue | SatelliteGuys.US
joethewop[
3
toronto
Hey guys, I have an issue with my slimline 3 install.
I get 101 and 103 np, but can't get 99.
I have aligned it and skewed it according to dishpointing guide but no luck.
I am missing a few Hd channels and I get 771 code on HD rec.
Any suggestions?
Joe
What are the signal strengths for 101 and 103? This can help us see if there is a slight anomaly.
You can get signals on 101 and 103 and nothing on 99.
A slight adjustment in elevation can help.
Thanks for replying so quick. I'm getting 95 on both 101 and 103.
They test fine on Rec config. only 99 comes up with XX
Are the BBC's the rectangular devices supplied bt DTV from RG6 to inputs to rec?
If they are, I installed them,
JTW
JTW
Yes, that's what they are. Which dvr/receiver are you using? What are the signal strengths on all of the satellites?
Missing Guide info since software upgrade
DirecTV Soccer channels
