Slimline 5 LNB - Which transponders to check Signal strength on? | SatelliteGuys.US
Rockstead
170
5
Earth
I'm just getting back in to Directv, years ago when I was just bringing in one bird, I remember having to go to the signal strength screen and verifying a certain transponder to determine if the strength was good or not.
With the 5LNB slimline, and the HR23, how do I verify the signal strength of each one and is there specific transponders I should be refering to for each?
Thanks!
You need to look at all TPs on each satellite. Look for anomolies. When making an alignment pick the lowest strength TP on 101 and tweak the dish to get it as high as possible. Then check the other TPs.
Newbie Needs Install Help
BET HD now live
