Sling Pic format with 922... | SatelliteGuys.US
bairda
8
Louisville, KY
I have had my 922 for several weeks and have a couple of questions regarding the sling functionality:
  • Is the sling pic coming from the 922 Standard Def only. I am assuming so, since the TV2 tuner it uses is SD. Is this correct?
  • If it is SD only, I have noticed that the formatting for the pic is sometimes squashed. Can't seem to find a way to get it to frame or expand correctly. Is there a way to do this or is this related to ? #1?
Thanks,
-Alex-
Thanks for the info!
Just to make sure I understand....even though the distribution to TV2 on the 922 is SD, the original signal that the sling function is sharing and outputting is HD?
-Alex-
Dealer programs
SlingPlayer App with Sling Adapter
