Sling Remote Learning! | SatelliteGuys.US
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,657
29,286
Newington, CT
As you know I test out a lot of equipment, and one of the things that I hate about the Sling is its inability to learn new remote controls. For example I got a few Free To Air satellite receivers that I can't use with my Slingbox because the Slingbox does not have the codes for the remote...
That is not a problem anymore..
Introducing http://betaremotes.slingbox.com/
Now your newer Slingbox can learn your remote controls. :)
VERY COOL!
I noticed tonight that the remotes I setup with this were not showing up in my Slingplayer. Went to the site and it just forwards you to their forums when you try to access your slingbox. I'm not very happy they took the remote function away for some of my stuff as they did not have it in their database.
GPS for Hunting
Wierd Win7 problem - must disable/enable devices at reboot
