Slingbox and Panasat 2700A | SatelliteGuys.US
ngriffin
28
Is anyone using a Slingbox with a Panasat 2700A or similar receiver? We are trying to set it up at work (we use it for SC ETV satellite classes). Video looks fine, but trying to get the remote control working (mainly channel up/down). Are there any known codes for it? Thanks.
link to files
my 3500S works great on my sling classic...
this site has the file that you put on your slingbox so it knows the correct codes, dont remember the exact file I used.
JP1 Remotes :: File Section
RTN, ThisTV, AMGTV & TuffTV schedules
RTN & AMC 9
