Sluggish / freezing DVR | SatelliteGuys.US
herlihyboy
Indiana
This may be a commonly asked question. If it is, forgive me. I have been a Direct customer for about 6 months. I have been disappointed by the "whole home DVR". IMO, it is inferior to Dish, which I had before (at least with the equipment I have). I have two TVs, one with an HD DVR and the other just with an HD Receiver. On the TV that just has a receiver, the DVR functions (skip ahead, pause, fast forward, etc.) are extremely sluggish and, at times, unresponsive. The show will also sometimes catch / freeze for several seconds.
Is there anything I can do on my own? Is this a known problem? Do I need to contact Direct about this?
TIA,
Ryan
TIA,
Ryan
Welcome to the site.
First thing you want to do is to do a Reset, and see if that helps.
Really need more info as in what recvrs are you using HR 24?, HRE21, H24 ????
What Dish set up are you using ?
SWM/ non SWM ( I would guess it's a SWM as it's most prevelent now.)
You can find all this info in your Menus on the recvr.
Menu/Settings/Info and Test/ Select/More System Info/ Select
Now to do a reset ...
Menu/Settings/ Reset/ReStart Recvr/ dash
The reset may fix your issue, if not, report back.
DIRECTV and Pandora Create Ultimate In-Home Music Destination
ESPN U Gone?
