I live in a Mobile Home Park, where I own my home. We all have our own yards. I have seen some 120cm dishes in another park like mine, and it was c-band. Just wondering what kind of reception you would get. Of course way back my 10ft c-band dish was using 120deg lnb. Not sure what the lowest deg are today.Much larger than any HOA is going to allow (because regulations only force them to allow 1m dishes).
This same question came up 12 years ago (and probably many times in between):
Smallest dish size for C Band
The search feature can be your friend if you let it.
Regardless of what you thought you saw, the recommendations seem pretty universal that you need something larger than 150cm for reliable results on the popular satellites. If you search as I suggested, other threads almost universally come to the same conclusion.I live in a Mobile Home Park, where I own my home. We all have our own yards. I have seen some 120cm dishes in another park like mine, and it was c-band.
I have been looking at houses lately and I was looking at some of the gated neighborhoods in central FL. They all have the large powerful HOAs and most have privacy fenced backyard. In that case, couldn't I not put up my 7.5" mesh on the smallest polar mount that allows it to turn and have it below or right at the fence line? Has anyone tried this?
If your fences are 6 feet high and you stick to satellites in the center of your arc, you can probably fix up a 7.5ft dish that doesn't poke over the fence line. A few 8ft bushes/trees in pots along the fence line between the dish and the street would further stealth your set up.
You need to ask the HOA what they will and won't allow. Their C&Cs are often composed of standard HOA boiler plate and as such, contemplate things that you might not expect (like requirements that you keep your section of the sidewalk free of snow).I have been looking at houses lately and I was looking at some of the gated neighborhoods in central FL. They all have the large powerful HOAs and most have privacy fenced backyard. In that case, couldn't I not put up my 7.5" mesh on the smallest polar mount that allows it to turn and have it below or right at the fence line? Has anyone tried this?
I agree, I wouldn't waste the money or time on a 4 footer. I have the same 7.5 footer (tight mesh reflector) for 23 years and it still serves it's needs, even for Ku, but if I was setting up a dish today it would be a 10 footer minimum.4 foot is the bare minimum, 6 foot really should be the bare minimum, and after installing either of those choices, you'll be disgruntled and WISH within a week or so that you had installed a 10 footer.
Assuming you have the acreage, the cost of "free" TV is much less than it used to be.So my question is what practical reason is there to have a C Band other than for nostalgia
So my question is what practical reason is there to have a C Band other than for nostalgia. I had one in the early 80's and still have a fascination just like I do for the LaserDisc player I used to own. I now have a Dish antenna which works better on my RV roof![]()
What are you doing with those other dish's you found? having them worked on? Where is my Christmas gift lol not for me for mom heheDid i hear minibud you won't get much but can get some things Lesea channels, 111w, 113w, 116w, just a few transponders but not much. Its not a lost cause but if you have no option for big dish then go this route.
Limited time offer
