Smallest Dish for 148w ? | SatelliteGuys.US
e0rbay
31
As some of you may have read in my other post... the installer who came and put up my second dish (for locals) put up a SECOND dish500.
So now I have these two ginormous dishes mounted off of my deck (I put up a mast off of one of the deck rails... didn't look so bad until the second dish was put up).
I'm wondering what's the smallest dish I could mount up that could pull my locals off of the 148 sat?
The 500 is 20" right? And then the 300 is 18"? Is there something smaller that might work? If so, where might I get one from?
Thanks for the info.
18 is what is reccomeneded. Of course you get less rain fade with Dish500, the smaller you go the more rain fade you will get. On good weather days you could probably do it with a 12" dish.
Splitting Dish signal
Need help with gettint the correct switch
